Use this category:
Solved [SOLVED] Installing 7.0.2 into Joomla 5.4.3 fails
8 months 6 days ago - 8 months 5 days ago #234802 by Formidog
Installing from web (joomla backend) results in "cannot find manifest".
Installing the downloaded version from the Kunena site results in a message that it cannot be installed in Joomla 5.2.2.
Site is 5.4.3
any solutions?
Dick
Last edit: 8 months 5 days ago by Formidog.
8 months 6 days ago #234803 by Gindi
If you click on System/Maintenance/Database in the backend, which manifest version is displayed there for the Joomla! CMS?
The following user(s) said Thank You: xillibit, Formidog
8 months 5 days ago #234804 by xillibit
If you look on the requirements : www.kunena.org/download Kunena 7.0.2 supports at minimum Joomla! 5.3.4. So you need to plan to make an upgrade of your Joomla! version at least to the 5.3.4 version
8 months 5 days ago #234805 by Formidog
Read the title!
My system IS 5.4.3
8 months 5 days ago #234806 by xillibit
Sorry, follow what Gindi has suggested above.
Are-you making a clean install of Kunena 7.0.2 ?
8 months 5 days ago #234807 by Formidog
Yep... didn't bother to look there.
I went by the "Joomla is up to date" message.
Thanks a lot.
Problem solved!
