- Thank you received: 1
Use this category:
Use this category:
Question Kunena 7.0 stable released : error restoring to a full backup of the site
8 months 1 week ago - 8 months 1 week ago #234355
by Sokrates
After restoring to a full backup of the site before the update of Kunena to 7.0.0 the front-end shows 500 error. The back-end shows:
Class "Kunena\Forum\Plugin\System\Kunena\Extension\Kunena" not found
Last edit: 8 months 1 week ago by xillibit.
8 months 1 week ago #234356
by xillibit
Replied by xillibit on topic Kunena 7.0 stable released for Joomla! 5.4 and 6.0
This is a leftover from Kunena plugin system from K7.0, try by uninstalling Kunena plugin system and install Kunena 6.4.8 above existing Kunena version
8 months 1 week ago #234357
by Sokrates
Replied by Sokrates on topic Kunena 7.0 stable released for Joomla! 5.4 and 6.0
"This is a leftover from Kunena plugin system from K7.0, try by uninstalling Kunena plugin system and install Kunena 6.4.8 above existing Kunena version"
I cannot access the backend.
I believe there is a way to enable debug without access to backend, but I cannot figure out how to do it.
- Thank you received: 2538
8 months 1 week ago #234358
by rich
Replied by rich on topic Kunena 7.0 stable released for Joomla! 5.4 and 6.0
You can enable Joomla debug mode on /root in the configuration.php file.
Search
and change it to
Search
$debug = false;
$debug = true;
8 months 1 week ago - 8 months 1 week ago #234359
by Sokrates
Managed to turn on debug and set error reporting to maximum.
Get the following:
An error has occurred.
0 Class "Kunena\Forum\Plugin\System\Kunena\Extension\Kunena" not found
Call Stack
# Function Location
1 () JROOT/plugins/system/kunena/services/provider.php:41
2 Joomla\DI\ServiceProviderInterface@anonymous/home/xxx/xxx/plugins/system/kunena/services/provider.php:24$9f->{closure}() JROOT/libraries/vendor/joomla/di/src/ContainerResource.php:168
3 Joomla\DI\ContainerResource->getInstance() JROOT/libraries/vendor/joomla/di/src/Container.php:95
4 Joomla\DI\Container->get() JROOT/libraries/src/Extension/ExtensionManagerTrait.php:177
5 Joomla\CMS\Application\CMSApplication->loadExtension() JROOT/libraries/src/Extension/ExtensionManagerTrait.php:99
6 Joomla\CMS\Application\CMSApplication->bootPlugin() JROOT/libraries/src/Plugin/PluginHelper.php:232
7 Joomla\CMS\Plugin\PluginHelper::import() JROOT/libraries/src/Plugin/PluginHelper.php:192
8 Joomla\CMS\Plugin\PluginHelper::importPlugin() JROOT/libraries/src/Application/CMSApplication.php:812
9 Joomla\CMS\Application\CMSApplication->initialiseApp() JROOT/libraries/src/Application/AdministratorApplication.php:332
10 Joomla\CMS\Application\AdministratorApplication->initialiseApp() JROOT/libraries/src/Application/AdministratorApplication.php:174
11 Joomla\CMS\Application\AdministratorApplication->doExecute() JROOT/libraries/src/Application/CMSApplication.php:304
12 Joomla\CMS\Application\CMSApplication->execute() JROOT/administrator/includes/app.php:58
13 require_once() JROOT/administrator/index.php:32
Get the following:
Call Stack
# Function Location
Last edit: 8 months 1 week ago by Sokrates.
8 months 1 week ago #234360
by Sokrates
Change "plg_system_kunena" i the database and now I can login to backend.
