- Thank you received: 1
Solved Unknown column 'socials' in 'SET'
regards
Did-you have migrated from K6.3.10 ? After that you have installed K6.4.2, did-you have been redirected or did-you have opened the Kunena dashboard ? Did-you have seen the messages (indicating which steps has been done one update) at the top of the page ?
i try to update kunena and no more message i ope it soleved
reagrds
- Thank you received: 162
There is no option. You just have to go to Kunena dashboard after installing Kunena 6.4.2 and then database will be updated and you can see this on top of your dashboard.but i my dashboard i didn't have this option
Sorry for the dutch language in the image, forgot to set my backend language to English.
What do you mean by that?i try to update kunena and no more message i ope it soleved
