Use this category:
Question 1071 Specified key was too long; max key length is 1000 bytes
2 years 1 month ago #232120 by Pinkeltje
xxx_wf_profiles is the profiles table for jce editor
The following user(s) said Thank You: AlexRag
2 years 1 month ago #232136 by xillibit
Thanks,
Are the ones starting with xxx__discuss are not Kunena?   I thought it was maybe Kunena Discuss extension.
If you had installed kunena discuss plugin, you will have a table nammed #__kunenadiscuss so your tables xxx__discuss are belonging to something else
