Use this category:
Solved Table problem when installing Kunena 6.2
3 years 4 weeks ago #229678 by micheldu42
I update my virtual site on wampserver to your new kunena 6.2 version then I got the error message as following :
Could you help to solve this trouble ?
Best regards
3 years 4 weeks ago - 3 years 4 weeks ago #229680 by xillibit
From which kunena version did-you tried the update to K6.2 ?
The table #__kunena_attachments exists since a while, in this case in phpmyadmin create the table with and then launch the update to version K6.2.0 :
CREATE TABLE IF NOT EXISTS `dzcoj_kunena_attachments` (     `id`            int(11)      NOT NULL auto_increment,     `mesid`         int(11)      NOT NULL default '0',     `userid`        int(11)      NOT NULL default '0',     `protected`     tinyint(4)   NOT NULL default '0',     `hash`          char(32)     NULL,     `size`          int(11)      NULL,     `folder`        varchar(191) NOT NULL,     `filetype`      varchar(100)  NOT NULL,     `filename`      varchar(190) NOT NULL,     `filename_real` varchar(190) NOT NULL default ''         COMMENT 'Filename for downloads',     `caption`       varchar(191) NOT NULL default '',     `inline`        tinyint(4)   NOT NULL default '0',     PRIMARY KEY (id),     KEY `mesid` (mesid),     KEY `userid` (userid),     KEY `hash` (hash),     KEY `filename` (filename),     KEY `filename_real` (filename_real) )     ENGINE = InnoDB     DEFAULT CHARSET = utf8mb4     DEFAULT COLLATE = utf8mb4_unicode_ci;
Last edit: 3 years 4 weeks ago by xillibit.
3 years 1 week ago #229876 by micheldu42
Sorry for my very late reply
I tried the update to K6.2 From K6.1.32
You said :" The table #__kunena_attachments exists since a while, in this case in phpmyadmin create the table with and then launch the update to version K6.2.0":
So I have followed your instructions and it appears it work fine now
Thank you very much for your help
