Use this category:
Sticky Problems when upgrading from K6.1 to K6.2
3 years 4 weeks ago #229688 by Leen
You could try your last question.
But also post a Kunena report we may see something more.
And do you sometimes use communitubuilder? I also encountered an old similar problem
www.joomlapolis.com/forum/255-developer-...ied-key-was-too-long
and it also seems to have something to do with the database sql collation to utf8mb4_general_ci
so if you use community builder
Could you also uninstall this first to see if that helps?
With kind regards
Leen
3 years 4 weeks ago #229689 by Petley
Thanks for the reply. No community builder installed.
I actually thought "f*ck it" what harm can I do, so I put the site in maintenance mode and then uninstalled the component, (this also uninstalled my paid template). I then reinstalled the full downloaded file and reinstalled an updated template all without errors and now I have the update site back
So fingers crossed all OK.
What worries me a little is the longevity of Joomla / Kunena as each of the recent upgrades to both seem to be winky bottom moments.
Cheers
Terry
Time to create page: 0.096 seconds
