Use this category:
Question Install Sample Data - Kunena Forum
3 years 1 month ago - 3 years 1 month ago #229444 by Indrit
Hello, I just installed the forum and when I try to install sample data, nothing happened. I click "Install" button and nothing happens.
Attachment not found
Please help
Indrit
Last edit: 3 years 1 month ago by Indrit.
3 years 1 month ago #229446 by Leen
The Kunena install data is sometimes also included in your question Joomla Home Dashboard ?
if so, try it there and see if it works
With kind regards
Leen
The following user(s) said Thank You: Indrit
3 years 3 weeks ago #229547 by Memotas
I have the same problem.
I installed the Kunena Forum v6.1.4 on the joomla 4.3.4 and when I try to install sample data, nothing happened. I click "Install" button and nothing happens.
PHP: 8.1
I also tried with PHP 7.4 and 8.0.
3 years 3 weeks ago #229549 by Leen
and the kunena sample install button is not visible in the Joomla dashboard as in my previous post?
With kind regards
Leen
3 years 3 weeks ago #229551 by Memotas
The button visible but no action occurs.
I can give you the site information if you want to review it.
I have been using this site for testing.
3 years 3 weeks ago #229554 by Leen
Unfortunately, the reference to your test site is not visible to me
but I have added the example data plugin from kunena as an attachment, will it work if you install that?
With kind regards
Leen
