Use this category:
Question Kunena broke Joomla
4 years 2 months ago #225122 by uzbaby
Kunena broke Joomla was created by uzbaby
Hello!
 I had some problem with image uploading to my Joomla and in Joomla support they say the problem is I Kunena.
My question was: Hello
When I want to add article in my Joomla 4 and go to tab: Images and Links....then Want to SELECT image from media it takes me to this page in the attachment. (404 error page)
what is wrong?
Can you please help?
So their answer after my FPA diagnosis was:
1. There is a problem with Kunena 6.0.2 but that is all I can see at the moment.
2. Looks like Kunena is causing an error? Check you have set Permissions correctly in it.
Also the logs folder is in the root which suggests your Joomla has been migrated. Possibly something in the migration failed?
Here is the link to our conversation: forum.joomla.org/viewtopic.php?f=811&t=9...0&p=3670371#p3670371
Can you please help? What went wrong?
4 years 2 months ago #225123 by xillibit
Replied by xillibit on topic Kunena broke Joomla
I have looked the topic on forum.joomla.org so the issue triggered is the following :
08-Sep-2022 02:00:04 America/Boise] PHP Warning: DOMDocument::load(): I/O warning : failed to load external entity "/home2/newuzbab/public_html/media/kunena/core/svg/contract.svg" in /home2/newuzbab/public_html/libraries/kunena/src/Icons/KunenaSvgIcons.php on line 68
The file is missing in the Kunena package, i need to look to find a way to fix it
4 years 2 months ago #225124 by uzbaby
Replied by uzbaby on topic Kunena broke Joomla
Hello xillibit!
Thank you
Should I provide you access to my website? Which data do you need?
4 years 2 months ago #225133 by xillibit
Try on the file /media/kunena/topic_icons/default/topicicons.xml at this line :
<icons type="system" width="48" height="48">         <icon id="500" name="moved" published="1" svg="contract" fa="compress"               src="system/moved.png"/>
to change the svg="contract" by svg="moved"
4 years 2 months ago #225158 by uzbaby
Thank you.
But before doing that maybe I should provide you with some other information. As I see in my extensions the Media Component of Joomla and Media component of Kunena are disabled. And they are locked and no folder is associated with them.
Here in the screenshot, you can see it.
So, should I add the code that you provided anyway?
4 years 2 months ago #225185 by uzbaby
Hello. Thank you! this code to the place you mentioned.
But nothing changed.
Maybe problem is because:
Maybe problem here?
