Use this category:
Solved Sample Data not installed
4 years 3 months ago #224091 by naderfrd
Hi I am trying to install Kunena Forum Sample Data and it fails Joomla 4.1.5
I tried this link which you Just what you suggested to peet but the Install button of Kunena Forum doesn't show on the Home Dashboard. I'm Using version 6.0.1.1 it was a new installation.
Also, I installed it for registered users to open on the Registered area. the menu shows on the registered area but by clicking on the forum menu and or submenus like New Topic and other subs, the page switches automatically to the public area.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload:
Joomla default template details : lt_law | author: LTheme | version: 4.0 | creationdate: Oct 2021
Kunena default template details : Aurelia | author: Kunena Team | version: 6.0.1.1 | creationdate: 2022-07-09
Kunena template params:
Kunena version detailed: Kunena 6.0.1.1 | 2022-07-09 [ Git Repository ]
Third-party components: CommunityBuilder 2.7.3
Plugins: None
4 years 3 months ago #224098 by Leen
Replied by Leen on topic Sample Data not installed
I don't know what went wrong but it looks like this is your kunena menu not really correct
have you sometimes changed something. in a quick test on my pc with sample data this is my kunena sample menu (image)
So I think maybe you start over with kunena via Kunena Forum: Tools > Uninstall kunena and then reinstall kunena again
With kind regards
Leen
4 years 3 months ago #224111 by rich
Replied by rich on topic Sample Data not installed
  • What happened to your Kunena menu? I can't see it in the configuration report. But Kunena needs it to work properly.
  • The menu items in your user menu are wrong ( Menu Issues ).
  • Install sample data
  • If you want to have the forum for registered users only, go to Configuration -> Security tab and select Registered users only = Yes
4 years 3 months ago #224153 by naderfrd
Replied by naderfrd on topic Sample Data not installed
Hi Rick and thanks for your replay. as Leen suggested, I Uninstall and then reinstall kunena again and the problem is solved but to have the Forum just for registered users, I did exactly as you said and activated "Registered users only = Yes" but when I click on the forum ((I added it in the special menu for registrants and not in the Public menu)), it still switches from the registrant's section and opens in the public section. Is it any way to prevent that? Thank you
4 years 3 months ago #224154 by rich
I'm sorry, but what do you mean by "it still switches from the registrant's area and opens in the public area".
With the "Registered Users Only = Yes" setting, the forum is not open to the public, and if you don't have a public menu item leading to the forum, guests can't even know you have a forum.
What is the difference between your public and registered area?
4 years 3 months ago #224187 by naderfrd
My site has two separate sections
The public section is the website's main page with a menu that shows information for the public.
A second part is a place where only members with usernames and passwords can enter and the menu there is entirely different from the public menu.
I want to use the forum for the second part, (just for members), which of course is displayed in the member's menu, but when I click on it, the main forum opens, but it no longer shows the users menu and instead shows the public menu. Please see the attached image
Time to create page: 0.170 seconds
