Use this category:
Question Upgrade to J4.1 / K6.0 breaks Cron
4 years 4 months ago #223612 by pcstech
Upgrading from a J3.10 to J4.1.5 and update to K6.0 appears to go ok. Except that Cron Jobs/CLI no longer work. Tracked issue to Kunena and find if I disable (Plugin)  System - Kunena Forum then crons work as scheduled - but obviously disable the forum!
So it appears there needs to be a simple check:
if (!$this->app->isClient('site')) return;
this line in the plugin's event handlers would make it J4 compatible:
If this is correct can it be added asap.?
4 years 4 months ago #223692 by pcstech
No ideas anyone? Where might i go about putting this ?
4 years 4 months ago - 4 years 4 months ago #223803 by xillibit
Try by using tihs :
if ($this->app->isCli()) return;
The method isCli() is deprecated and will removed in Joomla! 5.0 so it's a temporary solution but need to find an another way
Last edit: 4 years 4 months ago by xillibit.
4 years 4 months ago - 4 years 4 months ago #223811 by pcstech
Tried this in /plugins/system/kunena/kunena .php
And gives - An error has occurred.
0 Call to a member function isCli() on null
Last edit: 4 years 4 months ago by pcstech.
4 years 4 months ago #223813 by xillibit
The following user(s) said Thank You: pcstech
4 years 4 months ago - 4 years 4 months ago #223814 by pcstech
OK - that line seems to be working. Just checking a couple of cron jobs now - will confirm shortly.
Have confirmed now  and can confirm that the line 43 allows cron jobs to run without error.
Excellent - thank you. :)
