Use this category:
Question Kunena Installation Failed!
5 years 1 month ago - 5 years 1 month ago #219505 by brianronnow
Hey there,
I my client has tryed to update his forum and get the message below.
What can i do about it, so i kan install..?
Kunena Installation Failed!Sorry,
installation failed with following error:
502 Bad Gateway
Best regards
Brian Rønnow - www.nowweb.dk - www.cms-undervisning.dk
Last edit: 5 years 1 month ago by brianronnow.
5 years 1 month ago #219506 by Leen
Replied by Leen on topic Kunena Installation Failed!
What version of joomla does the website have and works the rest of the website ok?
With kind regards
Leen
5 years 1 month ago - 5 years 1 month ago #219573 by brianronnow
It uses the Joomla 3.10.2
Sorry for my late replay.. i have been sick
Best regards
5 years 1 month ago - 5 years 1 month ago #219574 by Leen
no problem
but is it possible that it is this website ? This Website
If so then there is something wrong with that because nothing works from Joomla there it seems.
maybe all menus should be checked again and built with the button or checked in
With kind regards
Leen
Last edit: 5 years 1 month ago by Leen.
5 years 1 month ago #219599 by brianronnow
No, it is  This website
Best regards
5 years 1 month ago - 5 years 1 month ago #219601 by Leen
did you install kunena just via administrator>Extensions: Install ?
Is there sometimes a security extension on the site?
Or set administrator > General settings tab sever Error reporting to maxmum maybe you will see more error message
when I scan the website I see the server Caddy I don't know that there might be anything with additional settings or security.
have you checked whether the server meets these minimum requirements
reguirements kunena
With kind regards
Leen
