Use this category:
Solved Installation fails at ~2% "Kunena Installation failed"
6 years 3 weeks ago #214386 by Ascott80
I am trying to install Kunena 5.19 and 5.20 for the first time on a Joomla 3.9.22, PHP 7.3.10.
Installation stops after ~2% without a specific error message. It just says "Kunena Installation failed."
It generates an Kunena entry in "Components" but every time I click on any of the menu entries the installation tries to start again and fails.
3 tables are generated in the database. kunena system plugin is shown as active.
I am running DJ Classifieds on the same Joomla Installation and need a forum in addition. All other plugins, modules, extensiosn are working flawless.
What I did:
- Checked and confirmed PHP-settings and server requirements.
- I deactivated all non-Joomla plugins
- I tried installation via web, URL, Package-upload, unzipped it and tried via tmp, installed package also separately (I dropped the generated kunena-tables and uninstalled all kunana-plugins every time and cleared the cache before trying antoher method)
The fact that only 3 tables are generated looks to me like a mysql-problem?
Can anyone help me? Happy to provide a donation. I would love to work with Kunena.
6 years 3 weeks ago #214387 by Leen
maybe the max_execution_ time or upload setting is too small
you could have a look at that at php.ini settings
minimal
but is already quite old so increasing the values to eg like this would be better
sample php.ini settings
With kind regards
Leen
6 years 3 weeks ago - 6 years 3 weeks ago #214390 by Ascott80
Thanks, checked all setting again and I even exceed some already. :(
BTW: Why does Kunena require allow_url_fopen: true?
Last edit: 6 years 3 weeks ago by Ascott80.
6 years 3 weeks ago #214391 by Leen
I don't know exactly why it should be on
but if a little googled then I come across in read more joomla itself that it is necessary
and if Kunena herself also says in explanation that he must, I assume that it is important.
With kind regards
Leen
6 years 3 weeks ago #214393 by rich
I'm not sure if it helps, but try the following:
First remove these 3 tables.
Then start the installation and when the installation stands, go to \administrator\components\com_kunena and remove the install.php
Then refresh in the backend the page.
6 years 2 weeks ago - 6 years 2 weeks ago #214396 by Ascott80
If I do that the installation procedure stops (as the page is refreshed) and I of course get the error msg:
"42S02 SQLSTATE[42S02]: Base table or view not found: 1146 Table 'XXXXXXXXXXX_2.u4l80_kunena_configuration' doesn't exist ".
Because no table exists and the installation procedure has been stopped.
I cannot refresh without cancelling the installation process?
Last edit: 6 years 2 weeks ago by Ascott80.
