Use this category:
Question error kunena plus joomla on wamp and xamp
6 years 5 months ago #213216 by chibitetsuo
hello,
since two day i have a little problem with kunena.
i use local installation with wamp.
the installation of kunena block on joomla. web installer, package, tmp folder.
joomla think kunena are note finish her installation i have a component..dashboard , category etc etc if i click on it...installation error thats all.
test on 2 different pc on windows 10
ps : i have different error message randomly
installation online have no problem.
thanks for reading and sorry for my bad english.
Attachment not found
6 years 5 months ago #213218 by rich
Enable the Joomla debug mode, maybe you see more exact error messages. But I think, it's a permission problem. Should be for folders 755 and files 644
6 years 5 months ago #213222 by chibitetsuo
in wamp and xamp no chmod atribute.
normaly no protection...
the only solution i have is :
create joomla on provider, install kunena
take database and joomla
and migrate to local server...
strange problem
6 years 5 months ago #213223 by Leen
do you run wamp with administrator rights in windows 10?
And isn't it a max_execution_time or max size problem?
and wamp is installed outside windows 10 folders
search for
With kind regards
Leen
The following user(s) said Thank You: chibitetsuo
6 years 5 months ago #213241 by chibitetsuo
hello :)
for win10 i am another repertory of windows but i have test both solution in and out i have the same problem
i am in administrator normaly.
i have friends of me he have tested and wamp version (previous) he have the problem but after he go in administration panel of kunena the installator finish the installation.
i don't have testé the response time of wamp. (i have augmented max size before)
6 years 5 months ago #213242 by chibitetsuo
@leen
re hello.
oki i followed you're advice. il modified execution and all parameter exactly the same way of readme.txt
before i used the webinstaller in joomla. i used the temps folder because i have a doubt of "joomla integrated web installer" and the magic goes on. kunena install in wamp and in other folder.
ps : in webhoster i have no problem kunena install very well :) thanks :)
