Use this category:
Question Fresh install from 5.1.15
6 years 9 months ago #212227 by carleo
Hello All,
First sorry if my english is uncorrect i'm french
I made a fresh install from
Joomla 3.9.15
Php 7.4.2
IIS 10 Express
Mysql Workbench 8 CE
www.obt.myddns.me
All plugin and components seems to be installed (compare from an other old website)
All table seems to be created (compare from an other old website)
But i'm stuck on the Error on Kunena Installation message en progression bar with no more details
Closing this message return me on joomla backend
When i try to acess kunena from component menu i get the install error message again
On the main joomla backend i get the Extension message " Please complete the Kunena installation"
When i try to acess kunen from the front menu, i get "Forum is offline"
Maybe you can light me on this issue
6 years 9 months ago #212237 by rich
Replied by rich on topic Fresh install from 5.1.15
Have been created all Kunena tables in the database?
Please try to install Kunena 4.0.12 first, then upgrade to the current version.
Maybe you must remove already existing *_kunena_tables previously.
Download unena 4.0.12 here: github.com/Kunena/Kunena-Forum/releases/tag/4.0.12
Probably you get errors during the installation (Kunena 4.0.12 is not written for Joomla 3.x) and therefore ignore these errors. When this installation is ready, then install Kunena 5.1 over it.
I hope it works.
6 years 9 months ago #212238 by carleo
Replied by carleo on topic Fresh install from 5.1.15
I try this and i inform you
6 years 9 months ago #212239 by carleo
Sadly its failed also but this time i have an information. The install failed at kunena_users_categories
6 years 9 months ago #212240 by rich
It seems something prevents to create the tables. I've added an attachment with all (empty) Kunena tables. So you can check which tables are missed and, if necessary, to create.
I don't know your SQL knowledge, but when all this tables in your database exist, it should be possible to install Kunena.
(In principle it could also work, if you import this file in your database and adjust the prefixes.) Try it on a test page first.
6 years 9 months ago #212243 by carleo
Hello
i push all the table on my database, but still the same result
Maybe i have a clue on this issue. Windows 10 lock the folder usage to read only. Not files but only the folder. May be the installer try to rename a folder and its is locked by windows security
I will try to overpass this, and i'll inform you
