Use this category:
Solved Weird display - Kunena looks corrupted
9 years 1 day ago #196806 by Matthieu OOT
Hello Kunena community,
I installed Kunena a couple of days/weeks ago now, and I'm experiencing weird CSS changes regularly.
Every second day or so, I note changes in my website's appearance, like buttons changing colors or such. At first I was not so sure whether the issue came from me or not (like failing to upload the updated css file on the server).
But today it got even worse with an additional "login" button being displayed next to the original one and more.
It is no longer mere button color changes but critical issues making the user experience pretty poor.
Please kindly find attached a screenshot.
You can also see the problem here: outoftrack.com/forum.html
These issues only happen to the Kunena section of the website.
Parts of these issues can be solved by changing the kunena.css file (not sure about the bouble login though), but should I expect to face these issues forever? Where do they come from?
Any idea how I can stop them for good and finally have a stable display?
Thank you very much,
Matthieu
9 years 1 day ago #196811 by rich
It seems, no bootstrap.css will loaded. Try in the template setting "Kunena -> Templates -> Crypsis -> Advanced" Load Bootstrap css = Yes.
9 years 1 day ago #196812 by Matthieu OOT
Thank you once again Rich for your help.
I tried this option, but I lose most of my icons. See attachment.
It is replacing one problem with another :-(
And I see other buttons are going corrupted...
Where does it all come from? How can I restore a stable version?
All was working (almost) perfectly fine till the issue came on its own...
Thank you for your support.
9 years 1 day ago #196813 by rich
Try in template setting -> Features:
Icon type = Fontawesome
Load External CDN Fontawesome = Yes
9 years 1 day ago #196814 by Matthieu OOT
It works!
Once again, huge thank you!
Still wondering how it came on its own, literally overnight, and whether I should expect more such changes in the future.
(Is there some type of automatic Kunena updates to turn off?)
Thank you.
9 years 1 day ago #196815 by rich
No, in principle should nothing changed by itself.
Kunena shows only when upgrades are available, but the upgrade is not automatically.
The following user(s) said Thank You: Matthieu OOT
