Use this category:
Solved Instalation of kunena failed
9 years 1 month ago #196480 by etrecords
During the installation of Kunena on a new setup website I got the information that the installation failed.
The last message in the detail window of the installation is teh installation of the finder module and this is marked as succesfull.
I got the following error message "Table 'DB3137039.#__kunena_configuration' doesn't exist" and also the message
Notice: Undefined variable: config in /mnt/web113/e1/11/51983211/htdocs/joomla_02/libraries/kunena/config.php on line 1297
The Joomla version is 3.8.1.
The website is hosted by Strato in Germany and running:
SunOS localhost 5.10 Generic_150401-49 i86pc
the PHP version in use is: 5.6.31
The database version is : 5.6.37-log
Joomla is installed using the installation app of Strato.
Even when I create the table manual the installation is failing. But in that situation I don't get any error messages.
9 years 1 month ago #196487 by rich
Replied by rich on topic Instalation of kunena failed
A similar problem had another German user with Strato. Maybe this solution helps.
www.kunena.org/forum/36-German/139062-ku...%C3%A4gt-fehl#181636
9 years 1 month ago #196495 by etrecords
I followed the suggestion done in this topic but it did not solve my problem.
After that I removed my site total and build it up again manual.
This means:
Unpacking the joomla 3.8.1 zip file locally on my PC and copy this files to my website using FTP.
Then configure the website (specify the database host, database name and database user and of course the super user)
After this I start the installation of Kunena and it was successful.
The point I don't understood is that I copied all the files of the installation package to a temp map in the server and did a compare between these files and the files in the actual website. (I have ssh access to my website).
Then I did not find any difference. The new installation I did from the same copy on the server. so all the files are equal.
9 years 1 month ago #196503 by rich
Yes, that's these mysterious errors that occur repeatedly, but you can't find the cause.
