Use this category:
Question Can not install Kunena
6 years 6 months ago #1 by spejset
Hi!
Now I've tried all the ways to install Kunene, but failed.
I get this error message:
Kunena installation failed!
Unfortunately, the installation failed due to this error:
{"success": true, "status": "33%", "current": "Installed Setup", "Log": "\ n \ t \ n \ t \ t
Installed Setup <\ / td> \ n \ t \ t \ n \ t \ t ... OK <\ / td> \ n \ t \ t <\ / td> \ n \ t <\ / tr> \ n \ t <\ / table> \ n "}
Can you help me with the installation if you get my admin login data?
Best regards
anders hidman
Sweden
6 years 6 months ago #2 by 810
Replied by 810 on topic Can not install Kunena
Try first cleaning cache.
backend - system - cache - clear cache
6 years 6 months ago - 6 years 6 months ago #3 by spejset
Replied by spejset on topic Can not install Kunena
Cleaning cach does not help. I have clened cach in my Joomla site and also in my browser, but installing Kunena still does not work.
I tried to install Kunena via Joomal1 > install from web.
Kunena Installation Failed!
Sorry, installation failed with following error:
{"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t
Prepare Installation<\/td>\n\t\t \n\t\t... OK<\/td>\n\t\t <\/td>\n\t<\/tr>\n\t<\/table>\n"}
I have Joomla! version 3.7.5 and...
...JomSocial version 4.3.4 and..
...EasyBlog version 3.9.24862 ..
...Jom Classifieds... installed
can these cause installation problems?
BR
Anders
Sweden
Last edit: 6 years 6 months ago by spejset.
6 years 6 months ago #4 by rich
Replied by rich on topic Can not install Kunena
Joomla 3.7.5 should not be a problem, but this version is not up to date.
Not sure whether this extensions has affect to the installation. But you can test it. Go to "Extensions -> Manage -> Manage" and search and disable this extensions. Then empty the cache and try it again.
6 years 6 months ago #5 by spejset
I unpublished all other extensions and then tried to install Kunena again, but it did not work.
Then I created a brand new Joomla! site and tried to install Kunena in it, with the same result, I get the same error message:
Now I hope you want to help me with the installation if I post all your adminastraton login data
BR
Anders Hidman
Sweden
6 years 6 months ago #6 by xillibit
Replied by xillibit on topic Can not install Kunena
Do-you have in the directory logs a file named kunena.php at the root of your Joomla! installation ?
6 years 6 months ago #7 by spejset
I really need your help installing Kunena.
All of the things I have received from you regarding this problem have not worked!
Please, let me send you all the management data for my site so that you can do the installation.
BR
Anders Hidman
Sweden
6 years 6 months ago #8 by 810
you can paste here the details, use [confidential*] [/confidential] tags, without the *
6 years 6 months ago #9 by spejset
OK, thanks!
I hope you succeed where I failed so many times!
Best regards
Anders Hidman
Sweden
Time to create page: 0.493 seconds
