Use this category:
Question Can not install Kunena
9 years 1 month ago #196009 by spejset
Hi!
Now I've tried all the ways to install Kunene, but failed.
I get this error message:
Kunena installation failed!
Unfortunately, the installation failed due to this error:
{"success": true, "status": "33%", "current": "Installed Setup", "Log": "\ n \ t \ n \ t \ t
Installed Setup <\ / td> \ n \ t \ t \ n \ t \ t ... OK <\ / td> \ n \ t \ t <\ / td> \ n \ t <\ / tr> \ n \ t <\ / table> \ n "}
Can you help me with the installation if you get my admin login data?
Best regards
anders hidman
Sweden
9 years 1 month ago #196020 by 810
Replied by 810 on topic Can not install Kunena
Try first cleaning cache.
backend - system - cache - clear cache
9 years 1 month ago - 9 years 1 month ago #196022 by spejset
Replied by spejset on topic Can not install Kunena
Cleaning cach does not help. I have clened cach in my Joomla site and also in my browser, but installing Kunena still does not work.
I tried to install Kunena via Joomal1 > install from web.
Kunena Installation Failed!
Sorry, installation failed with following error:
{"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t
Prepare Installation<\/td>\n\t\t \n\t\t... OK<\/td>\n\t\t <\/td>\n\t<\/tr>\n\t<\/table>\n"}
I have Joomla! version 3.7.5 and...
...JomSocial version 4.3.4 and..
...EasyBlog version 3.9.24862 ..
...Jom Classifieds... installed
can these cause installation problems?
BR
Anders
Sweden
Last edit: 9 years 1 month ago by spejset.
9 years 1 month ago #196026 by rich
Replied by rich on topic Can not install Kunena
Joomla 3.7.5 should not be a problem, but this version is not up to date.
Not sure whether this extensions has affect to the installation. But you can test it. Go to "Extensions -> Manage -> Manage" and search and disable this extensions. Then empty the cache and try it again.
9 years 1 month ago #196071 by spejset
I unpublished all other extensions and then tried to install Kunena again, but it did not work.
Then I created a brand new Joomla! site and tried to install Kunena in it, with the same result, I get the same error message:
Now I hope you want to help me with the installation if I post all your adminastraton login data
BR
Anders Hidman
Sweden
9 years 1 month ago #196083 by xillibit
Replied by xillibit on topic Can not install Kunena
Do-you have in the directory logs a file named kunena.php at the root of your Joomla! installation ?
