Use this category:
Question Scrollbars randomly dont appear in posts
9 years 5 months ago #186536 by Pebbbles
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : jsn_epic_pro | author: JoomlaShine.com | version: 6.1.1 | creationdate: 10/29/2015
Kunena default template details : Crypsis | author: Kunena Team | version: 5.0.7 | creationdate: 2017-03-31
Kunena template params:
Kunena version detailed: Kunena 5.0.7 | 2017-03-31 [ Gayal ]
Third-party components: UddeIM 3.8
Plugins: None
Modules: Kunena Latest 5.0.2 | Kunena Login 5.0.2
Scroll bars are randomly not appearing in the forum
9 years 5 months ago #186565 by rich
You mean the browser scrollbar on the right? Press STRG + F5, maybe the page is not complett loaded.
9 years 4 months ago #188331 by PieceOfCake
I must say I have the same problem since 5.0 migration (actually up to date 5.0.10, Joomla! 3.7.3, PHP 7.0)
The problem occurs really often but only with Google Chrome, never with Firefox, and Ctrlg + F5 solves the problem but the page seems to be fully loaded (no sign of activity for the browser, no javascript error)
9 years 4 months ago #188349 by Pebbbles
exactly the same here - Chrome is the one where the issue arises and I am using the most up to date version of all software - I have found no permanent solution to date
9 years 4 months ago #189472 by PieceOfCake
I was afraid to be the only one with this problem ;)
I tried to look at the chrome console (F12) and inspect the CSS code but it seems OK! The only thing that can be thougth about this is there is a jQuery incompatibility between Chrome and Firefox (and Edge and the others too)
PS : tried to report to Google Chrome dev teams but no answers
9 years 4 months ago #193670 by rich
@Peppples
I've found this code in your template_pro.css. Try it with a shorter time or disable this code complete for tests.
#jsn-page { transition: width 0.3s ease-in-out; -moz-transition: width 0.3s ease-in-out; -webkit-transition: width 0.3s ease-in-out; }
Time to create page: 0.165 seconds
