Use this category:
Question Installation issue: Joomla 3.7.2 Kuena 5.0.9
9 years 5 months ago #185779 by Doco
Hi there,
I am a bit troubled with the Installion of the Kuena extension on a fresh Joomlasite (has no other Extensions/plugins.
I used the joomla installer via upload and install filepackage i then encounter this error:
{"success":false,"html":"No action defined!"}
Installationdetails:
Installationpreparation
The strange thing is that the Buttons Kuena and Close are greyed out so i have to close the Browser Tab.
In the Joomla Backend it tells me to complete the Installation. The Kuena Backend appears in the menus.
I already tried deleting the cache and disable the Cache, multiple reinstalls and a databank repair. Sadly the error is still occuring in every installationattempt.
Any ideas?
9 years 5 months ago #185785 by rich
First create a backup from your database. Then remove all kunena tables from the database and empty the cache again. Now try to install Kunena via url.
Time to create page: 0.099 seconds
