Use this category:
Question Kunena duplicates posts
- romagromov
- Senior Member
When user replies in topic, Kunena duplicates posts 4-5-7 times.
It happens not always, but each day I should to delete extra duplicate posts.
Download Free Software for Windows absolutly free.
- Thank you received: 2538
- romagromov
- Senior Member
rich wrote: I think, it's at a single user where occours this problem. Is this right? Please see this topic: www.kunena.org/forum/k-4-0-support-archi...st-publication-error
No, it happens with different users.
User writing post and press send button. Then Kunena 10-20 seconds trying to send post, and finally duplicates post several times.
But it happens not always, but every day.
May be it happens with specific topics, but I'm not sure.
Are this users moderators?User writing post and press send button
Maybe therefore the user clicking again?Then Kunena 10-20 seconds trying to send post
You can test it. Write a post as moderator and double click on send button. The result are two messages.
If you try the same as a registered user, you get the message "Duplicate message ignored (or similar).
- romagromov
- Senior Member
No, those users - not moderators. Usual users.
Did you test it yourself? Test it also with flood protection (configuration -> tab security). Set the flood protection to value 10. If you still can send as normal user (with double click) 2 messages, then check the user rights.rich wrote: You can test it. Write a post as moderator and double click on send button. The result are two messages.
