Use this category:
Question Preview is not working after update to K5.0.6.1
9 years 8 months ago #184293 by titchagcreation
I updated Kunena from 5.0.4 to 5.0.6.1 but now Preview is not working anymore.
I am using the crypsisb3 template.
When I click on Preview tab it switches to the tab but the content preview is empty.
I noticed that the ajax call done on kPreviewHelper(previewActive) in the edit.js file was not returning success. Actually, I think the #preview_url is wrong . Actually this is its value "/forum/topic/edit.raw". For information, in my Joomla settings SEF urls, Use URL Rewriting and Adds Suffix to URL are set to Yes (Unicode Aliases is set to No).
As I kept a backup of my installation, I noticed that the url parameter for the ajax call was 'index.php?option=com_kunena&view=topic&layout=edit&format=raw' (instead of jQuery('#kpreview_url').val())
I put back this parameter to its old value and now it works so I think there is a problem with this new code maybe because of url rewriting?
I noticed in your forum that the value for #preview_url is /forum/topic/edit?format=raw.
Please could you fix it? or maybe do i need to do something to make it work correctly?
Time to create page: 0.098 seconds
