Use this category:
Solved Installation fails at first step
9 years 8 months ago #184171 by Abdngav
Hi there, I've downloaded the Kunena package, upload to joomla and it fails at first step, see screen grab. Can anyone help me understand why this is happening?
Many thanks,
Gavin
9 years 8 months ago #184190 by rich
Please empty the cache and try it again.
9 years 8 months ago #184205 by Abdngav
Hi Rich, thanks for replying. Yeah tried that a few times but still comes up with the same error unfortunately.
9 years 8 months ago #184207 by rich
Go to the Joomla global configuration -> tab Server and select "Error Reporting = Maximum". Maybe you get a error message. That would be helpful.
9 years 8 months ago #184208 by Abdngav
Thanks Rich, changed that setting. Do you know where I can see the error messages?
9 years 8 months ago #184210 by rich
Maybe you see a error message if you try again to install Kunena. Check also in the Backend -> Components whether Kunena is present in this dropdown menu. If yes, then click on it.
