Use this category:
Question Installation interrupt with the following error
I got the same error like NeilT ( www.kunena.org/forum/installation-issues...with-following-error )
i tried everything what you suggest at this thread.
nothing worked
php is updated to Version 7
i cleared also the Cache
i use the qualify template by xs web design.
please can anybody help me ?
and also to install every single packe one by one, without any error. but when i click then at components/ Kunena, the install mask will shown again and Interrupt with the same error.
please help,
you Need maybe Access? i can gave you
thanks a lot
without ~
I've nothing changed but seen the error message. You need a repair via ftp. Here is the solution (German language should not be a problem for you).but please tell me before you are deleting or changing some big stuff
www.kunena.org/forum/36-German/139062-ku...%C3%A4gt-fehl#181636
For all other users:
If you have a error message such as
Table 'DB2740107.#__kunena_configuration' doesn't exist SQL=SELECT * FROM #__kunena_configuration WHERE id=1
It seems, this is caused by a erroneous Joomla file when Joomla is installed via AppWizard (such as at Strato).
This could be a solution:
Download Joomla and unzip it. Upload all files (without the install folder) via FTP on your page. Then install Kunena again.
Important! Create a full backup previously.
but thank you a lot for your Kind Support ! i will try this when im back home, and write then again here
