Use this category:
Solved Installation failed
9 years 9 months ago #183435 by Theorim
Installation failed was created by Theorim
I just updatet my virtual Linux Server to ubuntu14.04 an installed joomla Version 3.6.5
When I try to Install the Kunena package via "Install from Web", I get the following error messages:
Warning
Failed deleting access.php
Failed deleting index.html
Failed deleting en-GB.com_kunena.tpl_blue_eagle.ini
Copy failed: /var/www/html/joomla/tmp/install_5891c86ff36e2/packages/install_5891c8703f995/site/attachment.php to /var/www/html/joomla/components/com_kunena/attachment.php
JInstaller: :Install: Failed to copy file /var/www/html/joomla/tmp/install_5891c86ff36e2/packages/install_5891c8703f995/site/attachment.php to /var/www/html/joomla/components/com_kunena/attachment.php
Component Update: Failed to copy site files.
Package Install: There was an error installing an extension: com_kunena_v5.0.6.1.zip
I have no warnings on my System and all folder permissions are on Status "writeable".
What can I do? Which additional information are needed?
Thanks in advance
Theorim
9 years 9 months ago #183440 by 810
Replied by 810 on topic Installation failed
Ok,
try to clean backend cache from joomla. then try to install it again.
9 years 9 months ago - 9 years 9 months ago #183449 by Theorim
Replied by Theorim on topic Installation failed
I cleaned the cache (System -> Clear Cache) and tried it again.
I've tested this two times and get the same error
Last edit: 9 years 9 months ago by Theorim.
9 years 9 months ago #183450 by 810
What you can try, with admin tools, is to set the correct permissions, maybe a sub dir has the wrong permission.
9 years 9 months ago #183451 by Theorim
With other plugins I have no issues.
Can you maybe give me a hint which folder oder subfolder can cause this problem?
9 years 9 months ago #183452 by 810
but the easiest way is to use the admin tools component.
