Use this category:
Question BBCode Problem after update.
9 years 10 months ago #183170 by ociosu
I've just updated Kunena to version 5.05
After update i found the following problems:
- BBCode toolbar is not shown anymore, in none of the templates. BBCode option is marked as ON in both Crypsis and Crypsisb3
- Attachments button does not work.
Any help would be hight appreciated.
9 years 10 months ago #183182 by Forsythracing
I am also experiencing the same issues as the user above has pointed out.Except I installed the update the day of the release and everythink was working correctly until yesterday.
9 years 10 months ago #183189 by 810
Replied by 810 on topic BBCode Problem after update.
1) try to rename the .htaccess file to .htaccessold then rename htaccess.txt to .htaccess
2) If that did not work, then try switch joomla template, and check if its still there the issue. if the issue is gone, then there is a conflict with your joomla template.
3) If all not working, then try to disable some other 3rt party plugins on joomla, looks there is a conflict on 1 of that plugins.
9 years 10 months ago #183194 by Forsythracing
810 wrote: 1) try to rename the .htaccess file to .htaccessold then rename htaccess.txt to .htaccess
Strange thing that it works perfect on my mobile (Iphone) Device but not when I am using my desktop pc.
I have switched the joomla template but the same issue presents itself no matter which theme I use.
Changed the renaming of the htaccess files still no joy.
The only other option left is the 3rd party plugins,Which seems strange as I haven't added any new 3rd party plugins and all was working when I upgraded the forum software on 2017-01-04 and this issue only developed yesterday.
9 years 9 months ago #183195 by 810
Maybe cache, please clear cache, on joomla and your browser.
9 years 9 months ago #183197 by Forsythracing
Unfortunately none of those suggestions worked.I even checked for a java update which there was one Updated but still no joy.
I am not sure which other options are available to solve this issue.
