Use this category:
Use this category:
Solved Kunena upgrade from 1.7 to 5.x with step 3.0.7 breaks
- Smoker_Creep
- Junior Member
9 years 10 months ago #181722
by Smoker_Creep
I know I'm late but I need to upgrade a Kunena Forum from 1.7 to an actual version ... so i read the instructions I found here in the forum.
I installed a fresh new Joomla 3.64 system and imported the users around 7500 ... works well
Now I copied all Kunena database tables to my fresh Joomla and changed prefixes of the tables.
I started to install Kunena 3.0.7 and than the installation breaks after Recounting forum statistics
the forum has ≈17700 messages in ≈3500 topics
Hope somebody maybe had the same problem at that installation progress step and can help?
thank you very much!!!
- Thank you received: 2538
9 years 10 months ago #181724
by rich
Kunena 3.0.7 will not work with Joomla 3.6.4. To skip this step and try it with Kunena 4.0.12, then upgrade to Kunena 5.0
In principle it should also work, directly from Kunena 1.7 to Kunena 5.0
Replied by rich on topic Kunena upgrade from 1.7 to 5.x with step 3.0.7 breaks
- Smoker_Creep
- Junior Member
9 years 10 months ago #181736
by Smoker_Creep
Replied by Smoker_Creep on topic Kunena upgrade from 1.7 to 5.x with step 3.0.7 breaks
9 years 10 months ago #181737
by 810
Replied by 810 on topic Kunena upgrade from 1.7 to 5.x with step 3.0.7 breaks
are the users id the same as on your old website?
- Smoker_Creep
- Junior Member
9 years 10 months ago #181738
by Smoker_Creep
yes I imported with a self written script with user IDs ...
now I checked with a script kunena user table if user exist in joomla user table and deleted a handful if not
I also checked posts if that users had one ...
than checked kunena messages too if there are userid's with no user in kunena user table ...
so made sure that users exist in joomla user and kunena messages tables but no success at the end, same error
are there any other parts in database that will be processed in the function that aborts?
Many many thanks for help!
- Smoker_Creep
- Junior Member
9 years 10 months ago #181739
by Smoker_Creep
I tried to proceed if I commend out $read[$id] = array_combine($list, $list);
than the database update runs through 4.0.12 ...
after that I'll get to the same error as with 3.0.7 it breaks at same step like shown in my first post ...
Time to create page: 0.259 seconds
