Use this category:
Question Log In button does not work
10 years 1 week ago #181586 by denisp
hello everyone!
I have just upgraded from kunena 4 to 5.
the log-in button, on the right of the navigation bar is "dead".
I mean that if I click on it I don't see anything.
And if I l click on "Log-in" in the bottom of each topic the #klogin points
to this button but the result is the same.
I had to activate the bootstrap CSS because my joomla template does not have it.
thanks in advance
10 years 1 week ago #181612 by 810
Replied by 810 on topic Log In button does not work
ok, then you haven't got the kunena menu on top. It should open the dropdown to login.
10 years 1 week ago - 10 years 1 week ago #181613 by denisp
Replied by denisp on topic Log In button does not work
I don't understand what you mean with "menu on top"... but if you want check it out here: www.professionalteam.biz/forum.html
Last edit: 10 years 1 week ago by denisp.
10 years 1 week ago #181615 by 810
ok, i can see the menu. But the dropdown is broken on Accedi.
Try backend - kunena - templates - crypsis - basic - Load bootstrap "yes"
10 years 1 week ago - 10 years 1 week ago #181616 by denisp
the option to "load bootstrap" is set on yes ... se attachment please
10 years 1 week ago #181622 by denisp
I tested the forum by switching the joomla template. With Beez3 the log-in button works fine.
So it is an issue in my joomla template.
right now I remedied in a quick and dirty way.
in the bootstrap CSS I commented the line /* position: absolute;*/
it is not elegant but now the dropdown shows up!
thanks for the support
