Question Style Problem
15 years 10 months ago - 15 years 10 months ago #80596 by Kurim
Style Problem was created by Kurim
Hallo zusammen vielleicht weiß einer von euch Rat.
So wäre es ja richtig:
Nach dem ich den Style gewechselt hab sieht es so aus:
Jedoch kann ich mir nicht erklären woher das hier kommt:
<h2 style="visibility: visible; "><span>Profil</span> von kurim (kurim) Bearbeiten</h2>
Weil richtig wäre es ja so:
<h2><span class="k-name">Profil von kurim (kurim)</span> <span class="kheadbtn kright"><a href="/index.php?option=com_kunena&amp;func=profile&amp;do=edit&amp;Itemid=136" title="" rel="nofollow">Bearbeiten</a></span></h2>
Legacy mode: Disabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Enabled | htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 1500M
Joomla default template details : rt_quasar_j15 | author: RocketTheme | version: 1.5.3 | creationdate: June 10, 2010
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.2)
Modules: Kunena Latest: Disabled or not installed | Kunena Stats: Enabled (Version : 1.6.2) | Kunena Login: Disabled or not installed
Last edit: 15 years 10 months ago by Kurim.
15 years 10 months ago #80640 by Kurim
Replied by Kurim on topic Re: Style Problem
nachtrag - ich hab festgestellt das alle "h2"-tags merkwürdig unterwegs sind
15 years 10 months ago #80648 by rich
Replied by rich on topic Aw: Style Problem
Was hattest du gewechselt?
15 years 10 months ago - 15 years 10 months ago #80657 by Kurim
Replied by Kurim on topic Re: Aw: Style Problem
ursprünglich hab ich:
siteground-j15-22 genutzt da tritt es nicht auf nun nutz ich rt_quasar_j15 welches bedeutend neuer ist
mit rt_gantry_j15 geht es auch ohne probleme
und joomla von Version 1.5.21 nach Version 1.5.22 upgedated
//nachtrag :)
This error is caused by gantry-buildspans.js file stored in components/com_gantry/js/ directory. This file manipulates with SPAN elements inside each accordion in FAQ plugin (also in Core Design Accordion plugin).
Solution
Just remove (or rename) gantry-buildspans.js file. To be honest I don't know what this file exactly does so please make sure you don't need the file (or ask RocketTheme).
js rausgekickt siehe da es geht - versteh mal einer was die da treiben
Time to create page: 0.153 seconds
