Please note: The Kunena project team takes NO responsibility for maintaining nor supporting anything in this category.
Question adding info under picture on posts page
8 years 1 month ago #1 by jshoeks
i wanna add city name under the picture in the post page.
Now i found that this should be generated from within the template in file template/blue_eagle/html/topic/default_profile_vertical.php
But is there anyway i can overwrite that one file and add this without it gets deleted on next update ?
Or do i have to make a complete copy of blue_eagle template and make the changes in that to make that template active ?
8 years 1 month ago #2 by jshoeks
is there really noone who can give me an answer on this ?
8 years 1 month ago #3 by 810
best way is to create a template override, then it will not be overwritten on a update.
8 years 1 month ago #4 by jshoeks
where is the documentation for this ?
i have not been able to find this.
if no docuementation, do you have an example/short description on how theese are made for kunena as you are not using views direct.
8 years 4 weeks ago #5 by jshoeks
hello ?
8 years 4 weeks ago #6 by 810
8 years 4 weeks ago #7 by jshoeks
As far as i know, when you use own templates like the one kunena uses, default overwrite methods doesn't work.
Speciel overwrite methoed has to be used..
And when i go in and click create for kunena/topic it doesn't create any for the files topic/default_profile_vertical.php
So thanx for a link to default Joomla behavior instead of giving a usefull answer that would help solve this challenge that i can only guess alot of other ppl are having too.
8 years 1 week ago #8 by jshoeks
still no go on any real help for this ?
8 years 1 week ago #9 by 810
copy components\com_kunena\template\blue_eagle\html\topic\default_profile_vertical.php
to:
templates\yourtemplate\html\com_kunena\topic\default_profile_vertical.php
Then there you can add your own html
8 years 1 week ago #10 by 810
Time to create page: 0.536 seconds
