Solved from where to get good icons for the forum?
2 months 4 weeks ago #235073 by Leen
You could try out fontawesome in the Kunena categories, for example, by entering *Kunena Forum: Categories > Category Icon:*.
You might be able to do something with this.
With kind regards
Leen
2 months 4 weeks ago #235074 by kardash
This should be a css file connected to kunena as in kunena 4.0.12
2 months 4 weeks ago #235075 by 9themestore
Check if your Joomla template supports FontAwesome. If not, you can load FontAwesome through your Joomla template and use the icons for your forum.
2 months 4 weeks ago #235076 by kardash
cassiopeia поддерживает Joomla FontAwesome?
2 months 4 weeks ago - 2 months 4 weeks ago #235078 by 9themestore
Yes, If you are using the Cassiopeia template you can use the FontAwesome 6 Free version.
Last edit: 2 months 4 weeks ago by 9themestore.
Time to create page: 0.204 seconds
