Solved from where to get good icons for the forum?
2 months 4 weeks ago #235072
by kardash
from where to get good icons for the forum? was created by kardash
2 months 4 weeks ago #235073
by Leen
With kind regards
Leen
Replied by Leen on topic from where to get good icons for the forum?
You could try out
fontawesome
in the Kunena categories, for example, by entering *Kunena Forum: Categories > Category Icon:*.
You might be able to do something with this.
With kind regards
Leen
2 months 4 weeks ago #235074
by kardash
Replied by kardash on topic from where to get good icons for the forum?
This should be a css file connected to kunena as in kunena 4.0.12
- 9themestore
- Premium Member
2 months 4 weeks ago #235075
by 9themestore
Replied by 9themestore on topic from where to get good icons for the forum?
Check if your Joomla template supports FontAwesome. If not, you can load FontAwesome through your Joomla template and use the icons for your forum.
2 months 4 weeks ago #235076
by kardash
cassiopeia поддерживает Joomla FontAwesome?
- 9themestore
- Premium Member
2 months 4 weeks ago - 2 months 4 weeks ago #235078
by 9themestore
Yes, If you are using the Cassiopeia template you can use the FontAwesome 6 Free version.
Last edit: 2 months 4 weeks ago by 9themestore.
Time to create page: 0.285 seconds
