Solved Change Topic icon if question is answered
Can the topic icon be changed automatically as soon as at least one question is submitted?
Regards
Robin
- Thank you received: 198
What icon type have you set in the Kunena Forum: Templates tab, Features?
Otherwise, try a different setting there to see if that helps.
With kind regards
Leen
- Thank you received: 2545
