- Thank you received: 7
Solved Migration from Joomla 4 to 5
Is there a procedure for the migration, i.e what to disable and then update and re-enable?
Currently the checker is showing potential issues for Kunena
Terry
- Thank you received: 2545
1. first create a backup of your website (it is optimal if you also back up all Kunena database tables and the folder /media/kunena separately).
2. then uninstall Kunena via the Joomla Installer!
3. if available, disable Kunena extensions
4. upgrade your Joomla version
5. install Kunena 6.4
6. go to the Kunena Dashboard after installation to update the Kunena tables
If there are no problems, that's all.
- Thank you received: 200
