Solved Migration from Joomla 4 to 5
1 year 4 months ago #233712 by Petley
Hello
Is there a procedure for the migration, i.e what to disable and then update and re-enable?
Currently the checker is showing potential issues for Kunena
Terry
1 year 4 months ago #233713 by rich
Replied by rich on topic Migration from Joomla 4 to 5
Which Kunena version do you have installed? It must be minimum Kunena 5.1 or Kunena 5.2, otherwise the further upgrae to Kunena 6.x will not work.
1. first create a backup of your website (it is optimal if you also back up all Kunena database tables and the folder /media/kunena separately).
2. then uninstall Kunena via the Joomla Installer!
3. if available, disable Kunena extensions
4. upgrade your Joomla version
5. install Kunena 6.4
6. go to the Kunena Dashboard after installation to update the Kunena tables
If there are no problems, that's all.
The following user(s) said Thank You: Petley
1 year 4 months ago #233714 by Petley
Replied by Petley on topic Migration from Joomla 4 to 5
Kunena 6.3.10
1 year 4 months ago #233715 by Pinkeltje
Make a backup first. You should be able to update (not migrate) to Joomla 5.3.2 and then download and install Kunena 6.4.4. without problems. Make sure to go to Kunena dashboard immediately after installing Kunena 6.4.4.
1 year 4 months ago #233717 by Petley
Thanks, does that mean I still have to uninstall Kunena begore I Update/Migrate?
1 year 4 months ago #233718 by Pinkeltje
No,  just update.
