Solved Get rid of "Category" label
- OldCharlie
- Senior Member
1 year 3 months ago #233552
by OldCharlie
Get rid of "Category" label was created by OldCharlie
I would lke the Kuena Topic to be less cluttered. How do I select to not display the category of the Topic? See attached photo.
- Thank you received: 162
1 year 3 months ago - 1 year 3 months ago #233553
by Pinkeltje
Replied by Pinkeltje on topic Get rid of "Category" label
With all due respect, but I think the background colors are even more busy and difficult for the eyes.
Easiest way is to add this to your user.css:
Or create an override for components\com_kunena\template\aurelia\layouts\topic\row\default.php
and delete rows 105 and 106
#kunena.layout .ktopic-category, #kunena.layout .started br {
display: none;
<span class="ktopic-category"> <?php echo Text::sprintf('COM_KUNENA_CATEGORY_X', $this->getCategoryLink($this->topic->getCategory(), null, $this->topic->getCategory()->description, KunenaTemplate::getInstance()->tooltips())) ?></span>
<br />
Last edit: 1 year 3 months ago by Pinkeltje.
- OldCharlie
- Senior Member
1 year 3 months ago #233581
by OldCharlie
Replied by OldCharlie on topic Get rid of "Category" label
Thanks, I used your answer whereby I deleted rows 5 and 6. I also removed the colors, so it's not so busy.
Now I'd like to delete when the topic was created and the category in the topic second level.
1 year 3 months ago - 1 year 3 months ago #233583
by Pinkeltje
It is your choice, but I would prefer hiding them with css to avoid problems after updating Kunena to a new version..
I think this is what you want to achieve:
#kunena.layout .started {
display: none;
- OldCharlie
- Senior Member
1 year 3 months ago #233592
by OldCharlie
I'm a newbie with .css
So I attached my .css file.
It does not work. I put the user.css file in the httpdocs folder/ What could I be doing wrong?
1 year 2 months ago #233593
by Pinkeltje
It depends on the template you use. Check the template documentation.
Time to create page: 0.217 seconds
