Solved Get rid of "Category" label
1 year 5 months ago #233552 by OldCharlie
I would lke the Kuena Topic to be less cluttered.  How do I select to not display the category of the Topic?  See attached photo.
1 year 5 months ago - 1 year 5 months ago #233553 by Pinkeltje
With all due respect, but I think the background colors are even more busy and difficult for the eyes.
Easiest way is to add this to your user.css:
#kunena.layout .ktopic-category, #kunena.layout .started br {     display: none; }
Or create an override for components\com_kunena\template\aurelia\layouts\topic\row\default.php
and delete rows 105 and 106
            <span class="ktopic-category"> <?php echo Text::sprintf('COM_KUNENA_CATEGORY_X', $this->getCategoryLink($this->topic->getCategory(), null, $this->topic->getCategory()->description, KunenaTemplate::getInstance()->tooltips())) ?></span>             <br />
Last edit: 1 year 5 months ago by Pinkeltje.
1 year 5 months ago #233581 by OldCharlie
Thanks, I used your answer whereby I deleted rows 5 and 6. I also removed the colors, so it's not so busy.
Now I'd like to delete when the topic was created and the category in the topic second level.
1 year 5 months ago - 1 year 5 months ago #233583 by Pinkeltje
It is your choice, but I would prefer hiding them with css to avoid problems after updating Kunena to a new version..
I think this is what you want to achieve:
#kunena.layout .started { display: none; }
1 year 5 months ago #233592 by OldCharlie
I'm a newbie with .css
So I attached my .css file.
It does not work.   I put the user.css file in the httpdocs folder/   What could I be doing wrong?
1 year 5 months ago #233593 by Pinkeltje
It depends on the template you use. Check the template documentation.
