Solved No Category-Icons after Update
1 year 7 months ago - 1 year 7 months ago #233054
by sglodek
No Category-Icons after Update was created by sglodek
I try to update an old site for my brother-in-law from Joomla 2.5 with Kunena 4.0.7 to Joomla 5 and Kunena 6. The update was done as following:
In Joomla 5 with Kunena 6.4.1 I can see only default category-Icons like a folder-symbol.
Actually the site is for testing available on 212.227.102.116/plesk-site-preview/betab...dex.php/kunena/index
The old site (Joomla 2.5) is availble at www.betabikes.de/kunena/index
Where do I have to place the icons so that they are shown as in Joomla 2.5 with Kunena 4.0.7? In the old installation the images were in ../media/kunena/category_images as 64x64 pixel gif-files. That works well and the images were automatically scaled to fit for Kunena 4.0.7-category-layout in the fronend (see link above).
In Kunena 6.4.1 I tried to place images into ../media/kunena/core/svg. That may work, but I have to create about 64 new images with 32x32 pixels because the original files were gifs and sized 64x64 pixels.
In Kunena 4.0.7 are two icons per category: one for the state "there are new posts in the category" and one for state "no new posts". The icons are named with the number of the category and the state on/off. For examle for category 2 there are two icons: 2_on.gif and 2_off.gif.
so I have these questions:
Siegbert
- create a new Joomla 3 installation
- copy all Kunena-tables from old database to new database
- install Kunena 5 and let Kunena do all neccessary updates
- install an new Joomla 5
- copy the Kunena-tables from Joomla 3/Kunena 5 to the Joomla 5 installation
- install Kunena 6 and let Kunena do all neccessary updates
- copy all files from old media-folder to the new media folder
- is it possible to use the old 64x64 gifs as category-images?
- What do I have to do, to use these images (which folder, which settings in Kunena-category)?
- Are there two images needed for a category-state "new posts" and "only old posts"?
Siegbert
Last edit: 1 year 7 months ago by sglodek.
- Thank you received: 196
1 year 7 months ago - 1 year 7 months ago #233055
by Pinkeltje
Replied by Pinkeltje on topic No Category-Icons after Update
Here is the documentation for when you want to use your own icons.
www.kunena.org/docs/en/custom%20adjustments/category-icons
And make sure icons are set correctly in Aurelia Features:
Last edit: 1 year 7 months ago by Pinkeltje.
1 year 7 months ago #233056
by sglodek
Replied by sglodek on topic No Category-Icons after Update
Thank you, that works.
- Thank you received: 2545
1 year 7 months ago - 1 year 7 months ago #233057
by rich
Replied by rich on topic No Category-Icons after Update
Last edit: 1 year 7 months ago by rich.
