Solved Change text (2)
1 year 10 months ago - 1 year 10 months ago #232737 by Hifi2you
Change text (2) was created by Hifi2you
I need a little help again
I have changed the text here
From Thank you to synes godt om (I like, in english) in the red circle
You guys helped me with that in this thread = www.kunena.org/forum/general-questions-a...e/168622-change-text
But how do i change the test fjern tak (Remove thank you, in english) to Fjern synes godt om  In the red circle
And will the text in the green circle change to synes godt om then the Remove thank you are changed to Fjern synes godt om
As it is now users can press Synes godt om botton, but it says xxxxxx users said Tak instead of Synes godt om
And then users press Synes godt om botton, but then it says Fjern tak, to remove it, and that should be Fjern Synes godt om
Hope you can help, and thank you
Last edit: 1 year 10 months ago by Hifi2you.
1 year 10 months ago - 1 year 10 months ago #232739 by Pinkeltje
Replied by Pinkeltje on topic Change text (2)
You can search for the words you want to translate in language overrides:
Or check out this video
Last edit: 1 year 10 months ago by Pinkeltje.
The following user(s) said Thank You: Hifi2you
1 year 9 months ago #232753 by Hifi2you
Replied by Hifi2you on topic Change text (2)
Thank you very much.
It works perfect
