- Thank you received: 7
Kunena 7.0.8 Released
Solved Disappearance of Recent Posts on the Forum
Unfortunately, I was preoccupied with other matters and did not track the exact date or circumstances that might have caused this.
I would assume that something happened on the server (especially since the hosting provider performed some maintenance during this time), but articles entered during the "missing posts" period are still present on the site.
The last Kunena update to version 6.3.6 was performed on 10 November 2024. The last backup (Akeeba) with the "normal" forum state was made on 25 November 2024.
I am so perplexed about how this could have happened that I am sharing this information primarily to inform Kunena developers and users, not expecting to uncover the exact cause.
However, I do have a practical question: is it possible to restore just the Kunena database fragment from the appropriate backup while ensuring that all of Kunena's connections with the site (Community Builder, Kunena Discuss, etc.) remain intact? For example, would it be sufficient to replace all Kunena-prefixed tables in the database with those from the backup?I am attaching two configuration reports from the smaller of the two websites—one from a backup restored on WAMP server and another from the current server (with the posts missing).
Signature:
Many thanks to Rich and the other advisors.
- Thank you received: 154
after your question, I did both.
Diagnostics and recount of statistics showed no errors. Everything on the forum remains the same (with lost posts).
Signature:
- Thank you received: 2537
Have you or another administrator changed the option in the Kunena menu item ‘Recent Topics’ from ‘Recent topics’ to ‘Newest topic’? If so, it could be that older topics which are still being discussed, have been moved so far back that you can no longer find them. This option lists the topics by creation date and not by topicality.
By the way, the collation of your life site database is utf8mb3, but Joomla and Kunena should have utf8mb4.
Apparently, some of the posts have disappeared. On the website that I gave as an example, the statistics look like this:There can sometimes be problems with the database, but the fact that this occurs on two different websites cannot be a coincidence. Are these posts still present in the database? Please check it.
After the incident
Total Messages: 2742 Total Sections: 3 Total Subjects: 368 Total Categories: 16
Before the incident
Total Messages: 2914 Total Sections: 3 Total Subjects: 378 Total Categories: 16
No, no options have changed during my absence.rich post=232586 userid=2198Have you or another administrator changed the option in the Kunena menu item ‘Recent Topics’ from ‘Recent topics’ to ‘Newest topic’? If so, it could be that older topics which are still being discussed, have been moved so far back that you can no longer find them. This option lists the topics by creation date and not by topicality.
Thank you for this instruction. I will fix the collation after I restore the forum. But surely this could not affect the disappearance of posts?By the way, the collation of your life site database is utf8mb3, but Joomla and Kunena should have utf8mb4.
(You already pointed out the problems with the collation to me a year or so ago. Then you suggested either fixing it yourself, or waiting for the collation to update when the Kunena is updated. I then chose the second option, and as far as I remember, it worked. Unfortunately, I can't tell you the exact date and check it, since the list of my previous posts /My Topics/ has been reset), Кстати, да
Signature:
Please try this:However, I do have a practical question: is it possible to restore just the Kunena database fragment from the appropriate backup while ensuring that all of Kunena's connections with the site (Community Builder, Kunena Discuss, etc.) remain intact? For example, would it be sufficient to replace all Kunena-prefixed tables in the database with those from the backup?
1. export all Kunena tables from the backup.
2. export all tables from the Community Builder too.
3. *create a complete backup of your live site.
4. remove the Kunena tables from the Live Page database
4. import all Kunena tables into the live page
5. then synchronise the users in Kunena -> Tools and recount the statistics.
6. synchronise this in the Community Builder as well
If there are differences between CB and Kunena afterwards, you would also have to exchange the Community Builder tables. Then repeat steps 5 and 6.
* If everything goes wrong, you can always fall back on your full backup.
It is unlikely that posts will disappear due to the incorrect collation. But something must have happened to the database if it was already adapted to utf8mb4. It does not change the collation by itself back. Could it be that an older backup was accidentally restored?Thank you for this instruction. I will fix the collation after I restore the forum. But surely this could not affect the disappearance of posts?
