Solved How to change text colours on Kunena?
2 years 1 month ago - 2 years 1 month ago #232313 by gjay
Hi there! I am running Kunena using the Socialize II template in dark mode, alongside jomsocial (using game dark mode template).
I have recently installed Kunena onto the site and the background is  dark just as I want it but all the text colours are dark too, which makes things unreadable.
Is there a way of brightening the text? I have had a look on the forums and documentation but I am still at a loss, this is a big learning curve for me at the moment :)
Please note the site is NSFW:
htaccess: Exists | PHP environment: Max execution time: -1 seconds | Max execution memory: 256M | Max file upload:
Joomla default template details : Socialize | author: JomSocial | version: 2.3.0 | creationdate: December 22,2023
Kunena default template details : Aurelia | author: Kunena Team | version: 6.3.5 | creationdate: 2024-09-22
Kunena template params:
Kunena version detailed: Kunena 6.3.5 | 2024-09-22 [ Git Repository ]
Third-party components: Jomsocial 4.9.3
Plugins: None
Last edit: 2 years 1 month ago by gjay.
2 years 1 month ago #232314 by 9themestore
Hi gjay,
If you can provide us with a link to your website, we can help you better. However, try adding the following CSS code to your custom.css file to see if it improves your forum.
body #kunena.layout { color: #fff; }
Kind regards,
The following user(s) said Thank You: gjay
2 years 1 month ago #232315 by Pinkeltje
Tip: make use of the built-in Developer's tool for Firefox (Ctrl + Shift + I for Windows or Cmd + Opt + I for Mac) or a similar alternative for other browsers. This tool allows you to retrieve the css definitions of each part of the site and where they are in which file. You can also use this tool to make changes to the css definitions in the relevant page of your site and immediately see what the effect is and add the changes yourself in the user.css file.
2 years 4 weeks ago #232350 by gjay
Thank you!
However editing this didn't seem to do anything. We really like the dark theme of the site.
However, posting the link here might not be a good thing as it is NSFW x
2 years 4 weeks ago #232354 by 9themestore
Hi gjay,
I think you should look for a dark Kunena template for your website if you want to be truly perfect.
2 years 4 weeks ago #232357 by gjay
Would you have any recommendations? :)
