Solved loadposition tag. Is it working?
2 years 2 months ago #232222 by cbal32
I am trying to use the {loadposition xxx} or {loadpositionid xx} tag inside a post but it seems not to be recognized. I can see it only as a plain text. In the Joomla articles it works as expected but not in the posts.
I am trying to load the Joomla Banner module there. I have activated the load position plugin of course.
Is there any way to do that? There are requests about this feature since 2012.
2 years 2 months ago #232223 by 9themestore
Hi cbal32,
The default template supports adding positions below the messages. You can assign modules to corresponding positions below each message (The position names follow the format kunena_msg_row_1, kunena_msg_row_2,...) The number of positions depends on the number of your messages.
The following user(s) said Thank You: cbal32
2 years 1 month ago #232225 by cbal32
I use NTS KAY, so it works as expected!!
Thank you..
