Solved Kunena view 'administrator' not found
2 years 2 months ago - 2 years 2 months ago #232149 by xamonix
Hi guys,
after editing Joomla4 user.css file at the backend, i got this error "Kunena view 'administrator' not found" when I try to save the changes in that file.
Everything was fine till now. The only change I made to the website was editing some Menu items, but I can't figure out what this has to do with the "fatal error".
Here is a video to show what happens:
www.screentype.net/screen.mov
Last edit: 2 years 2 months ago by xamonix.
2 years 2 months ago #232150 by sadw
I don't know true reason but in right corner I saw Joomla 4.4.3.
Kunena 6.3 needs Joomla: version 4.4.7 or greater (>= 5.1.3 recommended)
The following user(s) said Thank You: xamonix
2 years 2 months ago #232152 by xamonix
It's very strange really, because everything was fine before.
I don't think it's the version that's causing the problem because, as I said, before today everything was fine.
It's melting my head...
2 years 2 months ago #232153 by 9themestore
Hi xamoix,
Try to do some below steps to check the issue:
- First, use a FPT program  to remove the text line you just added.
- If it works properly, update your website to the Joomla latest version 4.4.8.
- Next, try adding a comment in the form /* YOUR COMMENT HERE */. Save it to see if it has the same problem as above?
2 years 2 months ago #232154 by xamonix
I've been analyzing all the changes I've made to the user.css in the last two days and I've found the cause of the problem, (but I don't know why it's happening).
The problem is this line of CSS that I added to user.css to use Sweetalert when displaying system messages:
.swal2-html-container { font-size: 0.9em !important; }
After removing the line, the user.css file can be edited again in the backoffice without any problem. I had to create another css file with just that line of CSS and place it in the template's css folder.
It's all very strange but the problem has been solved.
