Kunena 7.0.8 Released
Solved What is the Default New Topic Icon in position #1 meant to be called?
1 year 11 months ago #231955
by purezen
I've been using Kunena for many years and always wondered about this basic thing.
When you create a new message, I would like to know what the first default icon is meant to represent / be called ?
1st icon = ???
2nd icon = Important
3rd icon = Question
4th icon = Idea
5th icon = Loved
6th icon = Merged
7th icon = Deleted
8th icon = Solved
The reason why I am asking is because I use a custom template from 9themestore.com.
In my template, each icon is named at the top of a forum thread and the first icon has been assigned "Question", yet this doesn't seem correct ??
Regards
Derek
1st icon = ???
3rd icon = Question
4th icon = Idea
5th icon = Loved
6th icon = Merged
7th icon = Deleted
8th icon = Solved
Regards
Derek
- Thank you received: 153
1 year 11 months ago #231961
by Pinkeltje
Replied by Pinkeltje on topic What is the Default New Topic Icon in position #1 meant to be called?
When using svg it is document, when using Fontawesome it is file.
- Thank you received: 2537
1 year 11 months ago - 1 year 11 months ago #231970
by rich
Replied by rich on topic What is the Default New Topic Icon in position #1 meant to be called?
Do you use labels? The question symbol is standard for labels. You can change it.
Copy the labels.xml (path /media/kunena/labels) to
/components/com_kunena/template/aurelia/config/labels.xml (instead of Aurelia your template)
Change this line:
<label id="0" name="COM_KUNENA_LABELS_QUESTION" b2="question-sign" b3="question-sign" fa="question-circle" svg="question-sign" labeltype="primary"/>
to
<label id="0" name="your own text or let empty for no text" b2="question-sign" b3="question-sign" fa="question-circle" svg="name of your svg image" labeltype="primary"/>
Hint: You can use all svg names where you find in /media/kunena/core/svg/
Also own svg images are possible.
(Not tested with 3rd party templates)
Change this line:
to
Last edit: 1 year 11 months ago by rich.
The following user(s) said Thank You: purezen
1 year 11 months ago #231998
by purezen
Replied by purezen on topic What is the Default New Topic Icon in position #1 meant to be called?
Time to create page: 0.304 seconds
