- Thank you received: 2
Solved strange icon on login
From a design point of view I think I would've used BS colors since it would then match the sites color schema but thats me.
EDIT: or, perhaps something like this without the big white center. So its just a green/red/yellow ring around the avatar?
NOTE: I've increased the avatar size to 30px in this example
- Thank you received: 162
- Thank you received: 2538
@Bearsampp It seems that you have set Avatartype to Thumbnails.If you want to remove this, change the avatar type from Thumbnail to Normal in the Aurelia settings.
@Pinkeltje You will only see this color frame if you have setting "Icon Type = Fontawesome" and Avatartype = Thumbnail, Rounded or Circle in Aurelia.
Exactly. But as I understand Bearsampp doesn't want border to show, so he can just set icontype to Normal as I stated here
It sets the class to none, so borders are not shown.I really don't understand why you have a border with avatar type set to normal.
BTW: the blue button color is coming from your template. My screenshot is from a clean J5 install with only Cassiopeia and Aurelia.
@Bearsampp:
logout icon size is hardcoded in widget logout, so I wonder how you changed it.NOTE: I've increased the avatar size to 30px in this example
