Solved Remove X Button from CKEditor Toolbar
2 years 5 months ago #231650 by rob parker
How can I do that?  I expected that it would be controlled by the setting for "Show X button" in the Bbcode tab of the Aurelia template, but that has no effect - although it does work for Ebay, Instagram, ....
Rob
2 years 5 months ago #231652 by Leen
I can confirm that turning off the X button does not work here either
With kind regards
Leen
The following user(s) said Thank You: rob parker
2 years 5 months ago #231653 by Gindi
A permanent solution would be to delete the "x" directory in /media/kunena/core/js/plugins/.
gindi
2 years 5 months ago #231655 by rob parker
Since there doesn't seem to be a way to do it within the configuration options, I'll go for the permanent removal.
Rob
2 years 5 months ago #231659 by rich
It is possible that it no longer works due to the switch from Twitter to X and that nobody has noticed this yet.
If you want to remove all social share buttons, you can also do this with a customckeditor_config.js ( see here ).
Once you have created this, add two slashes in front of this entry in the custom file line 32:
from
{ name: 'social', groups: [ 'social' ] },
to
// { name: 'social', groups: [ 'social' ] },
2 years 5 months ago #231660 by rob parker
Thanks Rich.  That seems a much better solution than removing a folder.  I've already got one customisation in custom_ckeditor_config.js,
Rob
