Solved Images not shown in posts
2 years 5 months ago #231645 by rob parker
Images attached to posts in our forum are not showing, except for superusers.  The Kunena configuration option in the Upload tab has Show Images for Guests set to Yes, but images are not being shown either to guests or to registered users; they are shown for superusers.  A registered user can see attached images if they use the Reply action; in that case, the attachments appear (as expected) in the copy of the post in the Topic History section below the reply section.  This behaviour was also happening with K6.3.1, and possibly with K6.3.0.  The forum is using the Aurelia template.
We have a forum category "Post Pictures for Help With Identification", so it's really important for us to get this weird problem solved.
Rob
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 768M | Max file upload:
Joomla default template details : tc_blp | author: Rob Parker and Dave Torr | version: 20240620_1000 | creationdate: 11 December 2023
Kunena default template details : Aurelia | author: Kunena Team | version: 6.3.2 | creationdate: 2024-06-14
Kunena template params:
Kunena version detailed: Kunena 6.3.2 | 2024-06-14 [ Git Repository ]
Plugins: None
2 years 5 months ago #231646 by Gindi
Replied by Gindi on topic Images not shown in posts
Maybe it is because the Kunena version detailed: in the Kunena config settings says "attachmentProtection =1".
gindi
The following user(s) said Thank You: rob parker
2 years 5 months ago #231647 by rob parker
Sadly, changing that option does not solve my problem.
Rob
2 years 5 months ago #231648 by rob parker
But it does seem that is the solution.  The fix I needed to solve the problem for existing posts was to change the value of the "protected" field in the _kunena_attachments table from 1 to 0.  I'm assuming the option which I've now changed will prevent this happening for new posts with image attachments.
It seems to me that the existing documentation for Kunena is sadly lacking.  I've done a lot of searching to try to solve this before posting here, with no success.  There certainly no mention of it in the official documentation on this site; and the search facility within the documentation doesn't appear to work at all.   A mention in the FAQ section of the implications of setting the attachment protection option would be a good idea.  Fortunately, there are people in this forum who do understand how it works.
Thanks,
Rob
2 years 5 months ago #231658 by rich
Replied by rich on topic Images not shown in posts
This has nothing to do with the configuration of the attachment protection. The attachments should still be displayed for everyone. I have tested it, it is a bug and will add it to our bug list.
You can use Gindi's suggestion as a workaround until the bug is fixed. After that, all attachments should be displayed correctly again.
2 years 3 months ago #231916 by xillibit
Replied by xillibit on topic Images not shown in posts
I have just made a change to fix it, you can try this nightly build to test it : update.kunena.org/nightlybuilds/pkg_kune...4-DEV_2024-08-14.zip and update.kunena.org/nightlybuilds/pkg_kune...4-DEV_2024-08-14.zip
Can-you tell please if it better now with that change ?
Time to create page: 0.192 seconds
