Solved database error kunena_aliases
2 years 5 months ago #231375 by Sims
I want to copy the database of a website an get the error-message "dbbackup failed: ERROR 1032 (HY000) at line 3255: Can't find record in 'xxx_kunena_aliases'
How can I solve this problem in kunena_aliases?
Thanks!
2 years 5 months ago #231378 by Pinkeltje
What is the reason you only want to copy the database?
2 years 5 months ago #231379 by Sims
Replied by Sims on topic database error kunena_aliases
I want to test something and I will copy the website, too. But because I used Plesk copying is in two parts.
Does it makes a difference?
2 years 5 months ago #231380 by Pinkeltje
Could make a difference. Just backup your original site with Akeeba backup and restore on new location with kickstart. I've seen multiple problems when moving sites the way you do.
The following user(s) said Thank You: Sims
2 years 5 months ago #231381 by Sims
Thanks for the tip.
Copying this way worked fine.
