Solved Update Kunema and Design Template Aurelia
2 years 6 months ago #231243 by xamonix
I've made a lot of changes in aurelia template design (php files and css).
If I update Kunema those files and changes will be replaced by the new version?
Thanks.
2 years 6 months ago #231245 by Pinkeltje
If you did it the correct way by making overrides in your templates html folder and using a custom css file your changes will be unaffected. But always better to make a backup before updating.
The following user(s) said Thank You: xamonix
2 years 6 months ago #231255 by rich
