Solved Change language
2 years 7 months ago #231112 by Hifi2you
Change language was created by Hifi2you
Is it possible to change the text in the red square to Danish ?
It is the message that appears when you have written a private message.
2 years 7 months ago #231113 by Gindi
Replied by Gindi on topic Change language
You can find the text in "/language/en-GB/en-GB/com_kunena.ini" in column COM_KUNENA_BBCODE_SECURE_TEXT_GUESTS = "This message contains secure Information".
You can change the text accordingly in the Danish language file.
gindi
2 years 7 months ago #231114 by Hifi2you
Replied by Hifi2you on topic Change language
gindi
Can you guide me to find where it is ?
I cant find it
2 years 7 months ago #231115 by Gindi
Have you installed a test server with Joomla and Kunena on your computer or are you using a CMS installation with a hoster? Who is the hoster?
Which Joomla version and which Kunena version have you installed?
gindi
2 years 7 months ago #231120 by rich
Replied by rich on topic Change language
In the backend, go to System -> Language Overrides, select your language Danish – Site and click New.
In the “Language constant *” field, enter this code:
Enter your desired text in the text field and save it.
The following user(s) said Thank You: Hifi2you
2 years 7 months ago #231122 by Hifi2you
Perfect ;-) It works, thanks
